How can I get archive button?
Currently archiving is a three step process: three dots → refile → archive
Is there a way to get archive button when viewing specific email?
I have “mark as unread/read” button, I have “delete” button - and I will not really use either.
I have also plenty of empty space in top bar.
I tried disabling unified inbox and explicitly setting archive folder rather than relying on automatic detection per Archive multiple emails function lost in update... Long live the archive button! - #8 by stphn but it has not changed anything.
Which version of K9 do you use? I use 6.714 (Beta) and it works as described
6.603 from F-droid
Post must have at least 20 characters.
Fdroid also seems to host Beta versions, e.g. latest 6.714. Maybe you could try this? For me it works stable
tried, still not enabled
tried rotating to get longer bar - still not there
any idea what I can check? How this button looks for you?
See my post here:
Ah, I think I missunderstood you: I looked at scenario where I am in Inbox, then I mark messages and get the archive button as described.
But I think you have other scenario: opened the mail itself and you want to archive. Yes, then you can go to 3dot / refile / archive.
But you also can enable to show Archive button in header:
Settings / General Settings / Display / Visible Message Actions - here you can enable/disable actions, e.g Archive
Thanks so much! Not sure why it is not default and how it may be changed but it definitely solves it for me.
Thanks again!
