How do i turn on gmail instant push i dont have the option in settings. i have option only for polling
Are you using IMAP or POP? And which version of K-9 do you have installed?
imap i just used the default nothing changed
version 5.717 from fdroid
You will have to downgrade to 5.600 if you require push. See this recent blog post:
oh then im happy with the new version then.
i like the new design
