Folder tingie at top when selecting
When I select some one or more mail a folder looking ting a box with a down arrow appears top right. If I press it the selected mail disappears from the current folder. Where did it go? What does that icon do?
You can long-tap actions in the toolbar to get a popup with a textual description. Works in basically all apps :slight_smile: It is the archive feature. The selected mail is moved to the archive folder.
Ahh, thanks. That long press feature had totally skipped my attention.
