Feature Requests
I’d like for you to add a empty spam option like the one you have for trash instead of having to select all messages in the spam folder then delete all. Also I’d like for you to add an message sent sound. I’m never sure if anything was sent & I have to constantly check my sent folder to see if it was which is a bit of a nuisance.
I agree with Chesshurs.
I would like to see a sound effect on transmission.
I would also like a sound effect when deleting the trash.
Reply to all as an option for default reply please :slight_smile:
Anyway to get a calendar built into the app that will sync properly between accounts similar to em client or the Thunderbird desktop
