Feature request: better protection for server passwords
Hi there
Server passwords can shockingly easily be seen. Please implement a better protection for the server passwords.
Many thanks
Yes, this was available in older versions (you had to enter your device’s PIN first) but then it was just visible. It is a bad regression.
I believe this issue may already be fixed in beta v15.1 if you’re interested in testing the change. Thunderbird b15.1 is available for download here
Fix:
If you are still seeing a problem, please file a github issue using link in the forum banner.
