I recently started to use K-9, awesome app great job! I have an issue with the export settings, when i press it i choose which accounts do i want and I press export and nothing happens. I search through all my folders and no backup file to be found.
Did you disable your system’s file manager app?
oh no… but i have material from f-droid!
Why did you disable the default file manager? Its pretty important for stuff like this haha
files app is bloat! hahaha ok i ll guess i have to stick with it, i had the same issue with barinsta. i 've learned my lesson! thank you all!
