Meus e-mails estao ficando na caixa de saida o dia inteiro. Do nada ficou assim. Informa que é impossivel enviar a msg. Que chato isso. Ta atrapalhando meu trabalho
that is generally an indication that something likely changed with respect to your mail service provider (MSP). there are a range of possibilities, from dns to connectivity to an expiring password or change in supported authentication options. try going through the outgonig mail setup check –
settings/[account/]sending mail/outgoing server/next
and see what, if any, messages are returned.
additionally, have you tried doing a forced send from the outbox – select the outbox and then select the option to “send messages”. does that return any indication of an issue?
