Recently, I have a problem with automatically (and also by purpose) saving drafts. It always only saves the empty draft, no text or any is saved with.
But, in the list, i see the subject and the first two lines of the content, but when i open the mail, it’s completely empty. When i try to copy or to move them, k9 tell’s me, that it is impossible to move or copy mails which ar not synced with the server.
That seems reasonable, but, i checked my settings and i do not see what i probably missed. Syncing is set to automatic and all other settings, as far as i see are also correct.
I have the exact same problem since the last release. The extra carriage return issue in drafts is fixed but “sending empty” emails is killer. It seems to happen on responses to longer emails that are saved as a draft before sending. I sometimes see 4 or 5 garbage characters appending to the begining of the reopened draft. That is a signal that the draft will be sent empty. It is frustrating that the 2 preview lines in the sent email actually show part of the correct email but it is empty when you actually open it.
Same here. Situation is: I write an email (mostly in macOS Mail) and save the draft. My wife wants to check the wording but the email is displayed empty in her K-9 app. Annoying thing is: After this, the email is empty in my mail client as well and I have to rewrite it.
Thanks for looking into this. If any details needed, I will gladly provide.
Marc
