I need some help, k-9 is not working on xiaomi Poco x3 nfc as expected. It did well on Samsung S9 with the same configuration. It seems it is not syncing/saving sent mails.
Could you pls provide some support?
What are you trying to accomplish?
Writing a draft and saving it
Saving/syncing sent Email -
What are your Observations?
Cant save drafts. The option is greyed out.
Sent messages are sent out but are not saved neither local nor on imap server.
No error Messages for smtp/imap server configuration. Receiving/sending emails works fine
Sent folder is updated when I sent emails of the same imap account from other devices like a desktop pc.
Other info?
Same configuration worked fine on Samsung S9 duos -
What K-9 Mail version are you using?
5.728 see screenshots -
What Android version and device are you using?
Xiaomi Poco x3 nfc w/ miui12.07(android 10)
