does not fetch Inbox messages from IMAP server
For a few days now K-9 Mail does no longer fetch mails from IMAP inbox. I have no idea why, I did not change anything. We are using K-9 Mail on 4 android devices, onyl one device suddenly is in trouble.
I use K-9 V13.0 (as 2 other devices do), Android 15, Samsung Galaxy Tab S6 Lite.
Thank you in advance.
Usually it’d be good to check the Fetch and Send for that particular account.
  • Settings
  • Fetching mail
  • Incoming Server
  • Next
for Sending
  • Settings
  • Sending email
  • Outgoing server
  • Next
Maybe OAUTH needs a reset, or some other situation. Good luck!
Actually I can say that it works after having restarted the tablet. I am pretty sure that I already tried this a few days ago…anyway: I will observe this an will keep you informed.
