This arises from another post I made yesterday.
I thought K-9 was just randomly not liking emails for some weird reason. (my bad)
K-9 simply does not appear to pass on SMTP 515 errors.
It would be nice to get a notification when that happens. (when my fingers and eyes betray me)
IF K-9 does already do this then I must have a different issue with notifications and would like to find out what that might be.
Thanks to the team.
stphn
February 21, 2023, 10:38am
2
I just tested to send a mail to
test@test.cooo
And I got an error notification: Domain does not exist.
Is this what you expect? For me it looks good. I am using Beta 6.508
Nope. Not here. No error message. Mail stays in the outbox. (Also on latest beta)
stphn: That is exactly right! I see Figgerty has the same problem though.
Figgerty:
I was asked to check the following the other day:
Settings → [Account] → Notifications → Miscellaneous . enabled?
I also assume:
Settings → [Account] → Notifications → Include outgoing mail . selected?
I wonder why you have the same problem I do but Stphn does not?
hey stphn:
When I look at my K-9 logs I get this when I try to send messages from my outbox:
02-18 16:02:09.434 15479 15499 I MessagingController: Running command 'sendPendingMessages', seq = 11279 (background priority)
02-18 16:02:09.439 15479 15499 D Notification: allPendingIntents
02-18 16:02:09.453 15479 15499 I MessagingController: Scanning Outbox folder for messages to send
02-18 16:02:09.455 15479 15479 D ViewRootImpl@ea5a689[PopupWindow:6fa7842]: Relayout returned: old=[480,84][1068,516] new=[480,84][1068,516] result=0x1 surface={valid=true 544828452864} changed=false
02-18 16:02:09.457 15479 15479 D ViewRootImpl@15c9fb8[MessageList]: MSG_WINDOW_FOCUS_CHANGED 1
02-18 16:02:09.459 15479 15499 V MessagingController: Skipping sending message K9LOCAL:ca2e248f-5c25-4cec-823c-ab8d99ed3d19 (reason: error)
02-18 16:02:09.461 15479 15479 D ViewRootImpl@ea5a689[PopupWindow:6fa7842]: MSG_WINDOW_FOCUS_CHANGED 0
02-18 16:02:09.465 15479 15499 D Notification: allPendingIntents
02-18 16:02:09.468 15479 15499 I MessagingController: Command 'sendPendingMessages' completed
The line:
Is as descriptive as my log gets.
Is the description of the error in your logs any better?
Is it different from mine in any way?
Could you post that section for me?
