Créer un dossier
Why can’t we create a folder in each email address?
This very useful feature exists on Thunderbird and also on other email applications, but not in this one.
Could you bring this functionality?
Thank you.
K-9Mail does not allow you to create folders, so as an alternative, I will describe how you can create folders in Thunderbird and use them in K-9Mail on your smart phone.
1.Create a folder in Thunderbird.
2. Start K-9Mail on your smartphone.
3. Tap the three lines
4. Folder management
5. Tap the three dots in the upper right corner
6. Load the folder.
If you operate in this way, you can use the folder created by Thunderbird in K-9Mail.
