Crash in Android 12
FATAL EXCEPTION: main
Process: com.fsck.k9, PID: 14285
java.lang.IndexOutOfBoundsException: Index: 0, Size: 0
at java.util.ArrayList.get(ArrayList.java:437)
at android.widget.HeaderViewListAdapter.isEnabled(HeaderViewListAdapter.java:168)
at android.widget.ListView.dispatchDraw(ListView.java:3526)
at android.view.View.draw(View.java:22648)
at android.widget.AbsListView.draw(AbsListView.java:4443)
at android.view.View.updateDisplayListIfDirty(View.java:21520)
at android.view.View.draw(View.java:22376)
at android.view.ViewGroup.drawChild(ViewGroup.java:4528)
at android.view.ViewGroup.dispatchDraw(ViewGroup.java:4289)
at android.view.ViewGroup.recreateChildDisplayList(ViewGroup.java:4512)
at android.view.ViewGroup.dispatchGetDisplayList(ViewGroup.java:4485)
at android.view.View.updateDisplayListIfDirty(View.java:21476)
at android.view.View.updateDisplayListIfDirty(View.java:21511)
at androidx.drawerlayout.widget.DrawerLayout.drawChild(DrawerLayout.java:1478)
at com.android.internal.policy.DecorView.draw(DecorView.java:820)
at android.view.ThreadedRenderer.updateViewTreeDisplayList(ThreadedRenderer.java:534)
at android.view.ThreadedRenderer.updateRootDisplayList(ThreadedRenderer.java:540)
at android.view.ThreadedRenderer.draw(ThreadedRenderer.java:616)
at android.view.ViewRootImpl.draw(ViewRootImpl.java:4421)
at android.view.ViewRootImpl.performDraw(ViewRootImpl.java:4149)
at android.view.ViewRootImpl.performTraversals(ViewRootImpl.java:3309)
at android.view.ViewRootImpl.doTraversal(ViewRootImpl.java:2126)
at android.view.ViewRootImpl$TraversalRunnable.run(ViewRootImpl.java:8653)
at android.view.Choreographer$CallbackRecord.run(Choreographer.java:1037)
at android.view.Choreographer.doCallbacks(Choreographer.java:845)
at android.view.Choreographer.doFrame(Choreographer.java:780)
at android.view.Choreographer$FrameDisplayEventReceiver.run(Choreographer.java:1022)
at android.os.Handler.handleCallback(Handler.java:938)
at android.os.Handler.dispatchMessage(Handler.java:99)
at android.os.Looper.loopOnce(Looper.java:201)
at android.os.Looper.loop(Looper.java:288)
at android.app.ActivityThread.main(ActivityThread.java:7839)
at java.lang.reflect.Method.invoke(Native Method)
at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:548)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1003)
You left out all the needed details though, like Device / Rom / K-9 version.
My Pixel 6 on stock (now rooted) A12 works fine, before rooting it too.
… and maybe also the Build Number (found at the bottom of the “about phone” section). There have been 3 (I think) updates since the official android 12 release. I’ve had no issues with K-9 (betas) on my pixels with android 12-beta-3 through to current.
Android 12 Stock with Feb Update on Pixel 6 Pro
All good here on my P6 non-pro, still on January update.
When 1st setting up the device did you copy your apps over from another device? That messed up a lot of users/devices (incl. mine lol, but nothing related to K-9).
I’ve been using it since getting the device in October, never a single crash so far :woman_shrugging:
