Hello
Sorry but my English is too poor in order to explain my problem.
I continue in French.
K9mail derniere version sur Android
Je DOIS changer mes passwords sur deux comptes.
J’utilise K9Mail depuis environ 5 a 6 ans.
Aucun topic sur le web ne correspond a ma version actuelle. Tout est diferent
J’ai passe 1 h pour trouver sans resultat
Je me logge sur le compte ( j’en ai 4) dont je veux modifier le password
Puis Parametres generaux
Puis nom du compte
Je trouve le nom du compte concerne…wanadoo.fr
Mais, il n’y a pas de remplacer le password
Rien dans lecture ou recuperation ou envoi etc…
k9 Mail est tres bien mais question remplacer un password ce qui est hyper simple a faire partout dans le monde ( sur Orange et sur Thunderbird c’est visible tout de suite) n’est pas facile a trouver dans k9.
Reponse rapide s’il vous plait.
Thanks a lot
Translated online as I cannot speak french at all:
K9mail latest version on Android I MUST change my passwords on two accounts. I have been using K9Mail for about 5-6 years. No topic on the web corresponds to my current version. Everything is diferent I spent 1 hour to find without result I log in to the account (I have 4) whose password I want to change Then General settings Then account name I find the name of the account concerning… wanadoo.fr But, there is no need to replace the password Nothing in reading or recovering or sending etc… k9 Mail is very good but question replace a password which is very simple to do anywhere in the world (on Orange and on Thunderbird it is visible right away) is not easy to find in k9. Quick answer please.
First you need to change the password on the portal provided by your mail provider. Most probably you already did this.
Assuming that you are on a recent version of K9 (latest is 6.000) you can change the password used by K9 at
Settings / Account / Fetching Mail / Incoming Server
Settings / Account / Sending Mail / Outgoing Server
OK Done
Changing passwords is more difficult on K9 than Thunderbird ( 15 years using on PC) or Orange for instance. Much easy on Amazon or Netflix too. Changing password appears immediately when you click or rignt click on your account name .
On K9 changing password is hidden several levels deeper.
35 years using PCs and 27 years Windows and 16 years Thunderbird but Android an K 9 5 years long.
Now i have understood.
Thanks
Great I could help you! Could you please mark my comment as “Solution”?
