Hi! I use K-Mail for a long time, and I am glad you’re still working on it. Thank you! Now after upgrading to Android 11 and Mail 5.740 every time I’ll open K-Mail a notification wants me to give access to contacts. Oldschool as I am I don’t want that - is there a setting to stop that notification finally?
In previous Android versions there was a checkbox to tell the system to deny the permission and not ask again. It seems like Android 11 got rid of that. But in my test denying the permission twice was enough to not be prompted again.
Alternatively, you can open the system’s App info screen for K-9 Mail, select Permissions, select Contacts, then select the Deny option.
Hi, unfortunately this doesn’t work for me - Kmail insists on getting the access. I tried all those steps according to the system you suggested. In Kmail’s notification box that appears on my device it isn’t possible to deny - you can only ignore the box, but it seems that is not enough…
You should report this behavior to the LineageOS project. K-9 Mail depends on the system doing the right thing. The app will ask for the permission every time. But if the permission is permanently denied the system is supposed to return a deny answer right away without showing the permission dialog.
You can probably work around this behavior by granting the permission when starting the app and then revoking the permission via Android’s App permissions screen.
Wow - that worked! Thank you very much!
