Bellsouth.net Error During setup
I am resetting my bellsouth.net account on K9. It started giving me errors, so I deleted the account and trying to set it back up again.
I have the IMAP Server set to imap.mail.att.net
Security is SSL/TLS
Port 993
Username is my full email address
I have triple checked my password, used on my computer and online
The error I get reads:
Setup could not finish
Username or password incorrect
(Command:sensitive; response: #2# [NO, [Authenticationfailed], Login Invalid Credentials])
Any ideas on what I am doing wrong?
According to the undated document at:
https://www.att.com/support/article/email-support/KM1010472
it looks like att changed to using OAuth. If your mail client doesn’t support oauth2, as is the case with K-9, you need to set up and use what they call a “secure mail key” in place of the password.
The links on the above document give the details on doing this.
Thanks, I’ll check that out
