Hello, I have been a long time user of the disroot email. As of recent(past 3 days), it seems this has been running in the background killing my battery like crazy. I haven’t changed anything in the settings, nor have I added any new emails. So I’m clueless as to why this is happening.
Anyone else experiencing this? Any way to stop this? Thanks
Probably you need to post a debug log here and hope that someone can see what is going wrong. Or create a ticket on github with all required information
Is there a reason why you have poll and push enabled at the same time? I know that you wrote that you did not change anything in the settings and suddenly it started to drain.
Maybe you could give it a try and use pull only, and set poll frequency to never.
I assume you have looked at the app-level battery usage report on the device to confirm that it’s k-9 that is doing the drain, not something else. Also, do you have the battery usage for k-9 set to “optimized”?
Wouldn’t this lead potentially to situation that K9 no longer responds to push events? Normally I disable any kind of battery optimization on Apps I expect push notifications, e.g K9, Signal, etc
I wasn’t necessarily suggesting “optimized”, just asking - I think that that’s the default.
I think it depends on the device on how things are handled. I have both a tablet and phone set to “optimized”. The tablet doesn’t do “push” when the cover is closed. The phone, which is a secondary - not actively used - device, does “push” even when it is “asleep”.
