Dear all
Is there an Auto Sync function for K-9 Mail?
Or do I have to reload manually for new emails? Can i set up up?
Dear all
Settings - select your account - Fetching Mail - enable Push.
Is there a way that it can reload automatically rather than having to drag down from the first email?
That is exactle what the push or pull functionality is for:
Also folder classes might be relevant - can you check the values for pull/push, the configured folder classes for it, and also on the folder(s) you want to see the mails?
