Hello!
The last couple days I often get an Authentication failed notification from K-9 mail for two of my e-mail accounts.
When I tap on them they take me to the settings, everything there is correct, but on selecting “next” it tells me that my username or password are incorrect - they are not.
Then, sometimes the problem just goes away by itself. But now it has persisted for several days. I tried to find out what’s wrong, and noticed that everything works fine, when I disable my VPN. It has definitely worked with the VPN enabled though, since I have that for almost a year now, and it wasn’t an issue with K-9 mail, neither on this nor on two other devices.
I use ProtonVPN. Does anybody else have this issue and hopefully a solution? I would appreciate it!
