Any way to always load images?
Thanks in advance
Look at Settings / account / Reading mail / Always show images
Here you can select
  • No - you have to fetch them manually
  • From contacts - it will show images from mails sent from some of your contacts, other to fetch manually
  • From anyone - images will always be loaded
As this is a privacy setting I would recommend to go with No or From contacts
Thanks my friend solved
Could you please mark this as “Solution”? This will help others reading this thread as well.
