Alarm clock notification
Hey there! I enjoy using K9, but it has an annoying notification behavior. I use it on Android 14, and for some reason
  1. It requires “Alarms and reminders” in order to receive push notifications, although literally no other app with push notifications I could think of does require that.
  2. There isn’t any notifications categories under system “Notification settings”, like there is for other apps. I’m allowed only to disable or enable everything I get from K9.
We’re working on a support article for this. In the meantime have a look at the notes I just typed up: NEW ARTICLE: How to configure push folders · Issue #174 · thunderbird/knowledgebase-issues · GitHub
That’s definitely not the case. The app has a lot of notification categories.
Thank you! This is exactly what I needed. I think I’ll disable the push notifications then.
Your pics show Thunderbird, and I’ve installed K9. Should I switch to the other app?
Doesn’t matter. Both apps work the same in this regard.
