Add gmail with alternative domain
Adding a pure gmail (@gmail.com) works very well. However if the domain is different (for corporate account, for example), K9 doesn’t figure this out and continues the normal flow.
I managed to login to the corp account from the sign-in flow, after entering a different (fake) gmail account (to trigger the auth flow), but at the end it still didn’t work, because apparently the fake email is used after the flow completes, then editing the mail continues with the normal flow. Ideally there should be a checkbox to force gmail accounts (oauth flow), or check DNS to see the domains are actually handled by google.
OK, I managed to get it to work, just enter the correct username, then manual settings, then these settings worked (choose smtp|imap.gmail.com then OAuth 2.0 authentication):
Thanks for posting this! I had the same issue, but now have it working.
