Action triggering mid-swipe instead of on release
Hi folks!
Since the latest update (I’m on 11.1) it seems the swipe actions in the inbox are activating instantly once you’ve dragged far enough to the side, instead of waiting until you release as it used to do. For the first day of two this meant I was mistakenly deleting messages and having jarring experiences. Although I’ve mostly adjusted to it, I would definitely consider this a bug/accessibility issue (anyone with fine motor control issues could likely be bitten by this).
Was this intentional? I think this is poor UI and would kindly request y’all consider putting it back the way it was, which was working great. If there was a threshold that let you activate the action before releasing, it was previously set at a much more reasonable distance.
Thanks for reading!
It’s a regression. A bug report is open and been acknowledged by the development team.
