Accessibility version
Hello
What is the last version that k9 mail had with the font options for accessibility users?
We have just been forced and update on our devices and the text now is not readable, beforehand we were clicking search and using font size to reset these but all these options are gone.
We now have a email list but can’t read any subject lines
I believe the font size setting was removed in v11 so v10 would be the one you want.
It was removed from search in v20.
Thanks
It’s not in any change revision data I could see, but then again the initial change wasn’t where it disappeared from the original menu
Not sure if it’s included on the in app change notes. It’s included on the github ones.
v11 change log.
v20 change log.
