One of My 6 a o l accounts simply will not install. Password IMAP settings are all exactly the same as the others, and the password is accurate. Will not install on my S-10 and will not on my wife’s S10 e.
And all six of them worked fine for years on the old non beta version. In fact how do I get the non beta version back now that Play Store thinks I’m hooked into the Beta.
That with the beta version might be a Red Herring: AOL supports oauth which means that your mail app doesn’t work with the main AOL password any more but requires you to generate an app-specific password. Maybe they have switched your account to oauth…
