Why does a url link gets pasted in between < >?
Each time I paste a url link to the body of a message, the link ends up between these characters: < > like this:
https://www.amazon.com
I keep removing them before I send messages out but it is a pain in the butt. The recepient gets the message with a clickable link in between these html codes, but it is just not professional. Right now the version of k-9 mail is v6.710
Is there anything I can do to eliminate this problem?
My android is v10.
Answer on why can be found here:
OK, I guess it"s going to stay this way. Thank you for the explanation.
It’s not a random decision, see RFC 3986: Uniform Resource Identifier (URI): Generic Syntax
Your recipient’s software should remove those, though, so perhaps a bug report can be filed there if it’s Free open source software.
