Hello!
My Yahoo inbox hasn’t updated since Oct 30th. I’ve been using K9 Mail for my Yahoo mailbox for a while before then, so my settings were correct. And I do have a GMail also checked by K9 which does successfully refresh.
I am running K9 Mail v6.202 on Android 12.
My Yahoo Fetch Incoming Server settings are imap.mail.yahoo.com, Port 993, with the Proper Username and Generated App Password.
I checked the K9 Log with Debugging turned on and found the segment below repeated a few times.
11-11 17:58:21.016 20229 20253 D MessagingController: Last folder list refresh @ Mon Oct 31 00:14:04 EDT 2022. Refreshing now…
11-11 17:58:21.046 20229 20253 D RealImapConnection: Connecting to imap.mail.yahoo.com as imap.mail.yahoo.com/67.195.176.151
11-11 17:58:21.048 20229 20253 W com.fsck.k9: Accessing hidden method Lcom/android/org/conscrypt/ConscryptEngineSocket;->setHostname(Ljava/lang/String;)V (max-target-q,core-platform-api, reflection, denied)
11-11 17:58:21.048 20229 20253 W com.fsck.k9: Accessing hidden method Lcom/android/org/conscrypt/OpenSSLSocketImpl;->setHostname(Ljava/lang/String;)V (max-target-q,core-platform-api, reflection, denied)
11-11 17:58:21.048 20229 20253 W com.fsck.k9: Accessing hidden method Lcom/android/org/conscrypt/AbstractConscryptSocket;->setHostname(Ljava/lang/String;)V (max-target-q, reflection, denied)
11-11 17:58:21.049 20229 20253 E DefaultTrustedSocketFactory: Could not call SSLSocket#setHostname(String) method
11-11 17:58:21.049 20229 20253 E DefaultTrustedSocketFactory: java.lang.NoSuchMethodException: com.android.org.conscrypt.Java8EngineSocket.setHostname [class java.lang.String]
11-11 17:58:21.049 20229 20253 E DefaultTrustedSocketFactory: at java.lang.Class.getMethod(Class.java:2103)
11-11 17:58:21.049 20229 20253 E DefaultTrustedSocketFactory: at java.lang.Class.getMethod(Class.java:1724)
11-11 17:58:21.049 20229 20253 E DefaultTrustedSocketFactory: at com.fsck.k9.helper.DefaultTrustedSocketFactory.setHostnameViaReflection(DefaultTrustedSocketFactory.java:160)
11-11 17:58:21.049 20229 20253 E DefaultTrustedSocketFactory: at com.fsck.k9.helper.DefaultTrustedSocketFactory.setSniHost(DefaultTrustedSocketFactory.java:154)
11-11 17:58:21.049 20229 20253 E DefaultTrustedSocketFactory: at com.fsck.k9.helper.DefaultTrustedSocketFactory.createSocket(DefaultTrustedSocketFactory.java:135)
11-11 17:58:21.049 20229 20253 E DefaultTrustedSocketFactory: at com.fsck.k9.mail.store.imap.RealImapConnection.connectToAddress(RealImapConnection.java:236)
11-11 17:58:21.049 20229 20253 E DefaultTrustedSocketFactory: at com.fsck.k9.mail.store.imap.RealImapConnection.connect(RealImapConnection.java:211)
11-11 17:58:21.049 20229 20253 E DefaultTrustedSocketFactory: at com.fsck.k9.mail.store.imap.RealImapConnection.open(RealImapConnection.java:132)
11-11 17:58:21.049 20229 20253 E DefaultTrustedSocketFactory: at com.fsck.k9.mail.store.imap.RealImapConnection.hasCapability(RealImapConnection.java:690)
11-11 17:58:21.049 20229 20253 E DefaultTrustedSocketFactory: at com.fsck.k9.mail.store.imap.RealImapStore.listFolders(RealImapStore.java:153)
11-11 17:58:21.049 20229 20253 E DefaultTrustedSocketFactory: at com.fsck.k9.mail.store.imap.RealImapStore.getFolders(RealImapStore.java:111)
11-11 17:58:21.049 20229 20253 E DefaultTrustedSocketFactory: at com.fsck.k9.backend.imap.CommandRefreshFolderList.refreshFolderList(CommandRefreshFolderList.kt:17)
11-11 17:58:21.049 20229 20253 E DefaultTrustedSocketFactory: at com.fsck.k9.backend.imap.ImapBackend.refreshFolderList(ImapBackend.kt:51)
11-11 17:58:21.049 20229 20253 E DefaultTrustedSocketFactory: at com.fsck.k9.controller.MessagingController.refreshFolderListSynchronous(MessagingController.java:389)
11-11 17:58:21.049 20229 20253 E DefaultTrustedSocketFactory: at com.fsck.k9.controller.MessagingController.refreshFolderListIfStale(MessagingController.java:593)
11-11 17:58:21.049 20229 20253 E DefaultTrustedSocketFactory: at com.fsck.k9.controller.MessagingController.synchronizeMailboxSynchronous(MessagingController.java:581)
11-11 17:58:21.049 20229 20253 E DefaultTrustedSocketFactory: at com.fsck.k9.controller.MessagingController.lambda$synchronizeMailbox$3(MessagingController.java:556)
11-11 17:58:21.049 20229 20253 E DefaultTrustedSocketFactory: at com.fsck.k9.controller.MessagingController.$r8$lambda$ar_6eNiqt1c67rfo1nCyGoIX3Sg(Unknown Source:0)
11-11 17:58:21.049 20229 20253 E DefaultTrustedSocketFactory: at com.fsck.k9.controller.MessagingController$$ExternalSyntheticLambda20.run(Unknown Source:10)
11-11 17:58:21.049 20229 20253 E DefaultTrustedSocketFactory: at com.fsck.k9.controller.MessagingController.runInBackground(MessagingController.java:223)
11-11 17:58:21.049 20229 20253 E DefaultTrustedSocketFactory: at com.fsck.k9.controller.MessagingController.access$000(MessagingController.java:109)
11-11 17:58:21.049 20229 20253 E DefaultTrustedSocketFactory: at com.fsck.k9.controller.MessagingController$1.run(MessagingController.java:164)
11-11 17:58:21.049 20229 20253 E DefaultTrustedSocketFactory: at java.lang.Thread.run(Thread.java:920)
11-11 17:58:51.152 20229 20253 W RealImapConnection: Could not connect to imap.mail.yahoo.com/67.195.176.151
11-11 17:58:51.152 20229 20253 W RealImapConnection: java.net.SocketTimeoutException: failed to connect to imap.mail.yahoo.com/67.195.176.151 (port 993) from /10.1.10.1 (port 35924) after 30000ms
11-11 17:58:51.152 20229 20253 W RealImapConnection: at libcore.io.IoBridge.connectErrno(IoBridge.java:236)
11-11 17:58:51.152 20229 20253 W RealImapConnection: at libcore.io.IoBridge.connect(IoBridge.java:180)
11-11 17:58:51.152 20229 20253 W RealImapConnection: at java.net.PlainSocketImpl.socketConnect(PlainSocketImpl.java:142)
11-11 17:58:51.152 20229 20253 W RealImapConnection: at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:390)
11-11 17:58:51.152 20229 20253 W RealImapConnection: at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:230)
11-11 17:58:51.152 20229 20253 W RealImapConnection: at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:212)
11-11 17:58:51.152 20229 20253 W RealImapConnection: at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:436)
11-11 17:58:51.152 20229 20253 W RealImapConnection: at java.net.Socket.connect(Socket.java:621)
11-11 17:58:51.152 20229 20253 W RealImapConnection: at com.android.org.conscrypt.AbstractConscryptSocket.connect(AbstractConscryptSocket.java:156)
11-11 17:58:51.152 20229 20253 W RealImapConnection: at com.fsck.k9.mail.store.imap.RealImapConnection.connectToAddress(RealImapConnection.java:241)
11-11 17:58:51.152 20229 20253 W RealImapConnection: at com.fsck.k9.mail.store.imap.RealImapConnection.connect(RealImapConnection.java:211)
11-11 17:58:51.152 20229 20253 W RealImapConnection: at com.fsck.k9.mail.store.imap.RealImapConnection.open(RealImapConnection.java:132)
11-11 17:58:51.152 20229 20253 W RealImapConnection: at com.fsck.k9.mail.store.imap.RealImapConnection.hasCapability(RealImapConnection.java:690)
11-11 17:58:51.152 20229 20253 W RealImapConnection: at com.fsck.k9.mail.store.imap.RealImapStore.listFolders(RealImapStore.java:153)
11-11 17:58:51.152 20229 20253 W RealImapConnection: at com.fsck.k9.mail.store.imap.RealImapStore.getFolders(RealImapStore.java:111)
11-11 17:58:51.152 20229 20253 W RealImapConnection: at com.fsck.k9.backend.imap.CommandRefreshFolderList.refreshFolderList(CommandRefreshFolderList.kt:17)
11-11 17:58:51.152 20229 20253 W RealImapConnection: at com.fsck.k9.backend.imap.ImapBackend.refreshFolderList(ImapBackend.kt:51)
11-11 17:58:51.152 20229 20253 W RealImapConnection: at com.fsck.k9.controller.MessagingController.refreshFolderListSynchronous(MessagingController.java:389)
11-11 17:58:51.152 20229 20253 W RealImapConnection: at com.fsck.k9.controller.MessagingController.refreshFolderListIfStale(MessagingController.java:593)
11-11 17:58:51.152 20229 20253 W RealImapConnection: at com.fsck.k9.controller.MessagingController.synchronizeMailboxSynchronous(MessagingController.java:581)
11-11 17:58:51.152 20229 20253 W RealImapConnection: at com.fsck.k9.controller.MessagingController.lambda$synchronizeMailbox$3(MessagingController.java:556)
11-11 17:58:51.152 20229 20253 W RealImapConnection: at com.fsck.k9.controller.MessagingController.$r8$lambda$ar_6eNiqt1c67rfo1nCyGoIX3Sg(Unknown Source:0)
11-11 17:58:51.152 20229 20253 W RealImapConnection: at com.fsck.k9.controller.MessagingController$$ExternalSyntheticLambda20.run(Unknown Source:10)
11-11 17:58:51.152 20229 20253 W RealImapConnection: at com.fsck.k9.controller.MessagingController.runInBackground(MessagingController.java:223)
11-11 17:58:51.152 20229 20253 W RealImapConnection: at com.fsck.k9.controller.MessagingController.access$000(MessagingController.java:109)
11-11 17:58:51.152 20229 20253 W RealImapConnection: at com.fsck.k9.controller.MessagingController$1.run(MessagingController.java:164)
11-11 17:58:51.152 20229 20253 W RealImapConnection: at java.lang.Thread.run(Thread.java:920)
