I’m using K9 Version 5.802 (the new one) and facing some issues.
The synchronization with the mail server does not work as expected.
- Deleting mails using the app, does only work locally. Which means they are not deleted on the server. The Fetching mail setting ‘When I delete a message’ is already set to ‘Delete from server’.
- Also issues with the read/unread function. Sometimes it works sometimes not. Unfortunately, it seems random to me. Sometimes I mark as read and after a while it is marked as unread again.
Any ideas what to do?
Or should I create an issue on GitHub?
All the best
