Strange things happens in K9 Android. Currently I’m using version 6.400. I suspect some changes around 11th October maybe responsible for this.My last action on folders was the cleanup of the “deleted” folder (probably around this time), but I haven’t change the folder setup at all.
- The formerly used “deleted” folder (in german named “Papierkorb”) isn’t used any more (since the above mentioned date). I’m not able to select this folder which previous used one any more, even if I reload and update the folder list. It has been automatically reset to “none”.
- Also the drafts, spam and archive folder definitions are gone. I have a folder named “Entw&APw-rfe”, “Spam” and “Archiv”, All has been set to “none”. I’m not able to reselect them, see below.
BTW: is it possible to create or just define a folder in K9 (Android) even it is not existent.or is created on-the-fly?
BTW #2: The folder list for selecting special folder is presented unsorted and incomplete (I have 1500) which is a real pain to go through to select one …
Best wishes
Johann
