[Solved] K9-Mail / OpenKeychain does not find key file
since the update to Android 11, K9 does not work correctly with OpenKeychain.
K9 is connected to OpenKeychain but I can’t select a key. under “Configure end-toend key”.
Version K9 - V 5733
Openkeychain V 5.7.2
Android 11 on Xiaomi Mi 10T Lite with MiUi 12.0.1
Thanks for the support
What happens if you press the “Configure end-to-end key” button? A crash?
See How do I make K-9 Mail work with OpenKeychain on Xiaomi's MIUI?
Thanks cketti for the Link, that works!
