CMcc
#1
I have a Samsung Galaxy s20+
Trying to set up a work email that uses gmail. I set up 2FA and am using an app password but when I continue I get this message:
Setup could not finish
Cannot connect to server.
(Unable to open connection to SMTP server.)
I’ve also got the k9-log.txt if that helps
What settings are you using for your “outgoing mail server”? If you’re trying to use the gmail server for outgoing, the settings should be:
server name: smtp.gmail.com
security: starttls
port: 587
require sign-in
authentication: normal password
password:
if your work is using a paid-for gmail service, with their own domain name, it’s possible that the outgoing server name is different.
[please always include the k9 version when reporting issues.]
