Hi there,
is there an option to have K9 ignore all SSL Certificate problems? A popup warning you about a problem but with the option to go ahead anyway would be just as good if it existed.
Yes, I am extremely well aware of the security implications.
I’m not sure about the beta, but 5.600 mostly does what you’re asking. It will pop up a warning on untrusted certs, but if you accept the warning it will remember that selection and not ask again until the cert changes.
Thank you, you are correct.
For some reason, the popup fails to display on my old phone, which causes the mail app to not accept the certificate. I double checked with a different phone where the popup appeared and it works correctly there. All is good
