Dear all,
While using the Search-function I noticed that it doesn’t work properly.
This issue has been and is still in existing since min. last year.
I tap the magnifier, keyboard opens, I type something to look for, after 2 to 3 seconds the “input bar” disappears, erasing the search. Keyboard ist still visible and every letter you touch now (still assuming you’re using the search function) results in a probable command like ‘sort by date’, delete, or something else.
Seems to be a programming error… Please fix it.
Matthias
P.S.:
I’m using a Samsung S10e mobile device, Android 12 (same issue with Android 10 and 11), Samsung One UI 4.1, K9 5.915.
