I’ve been using K9 for a while so not downloading mail is new. It seems to have started sometime over the weekend when I was too busy to check it.
Two email accounts, my gmail is still downloading fine, but yahoo stubbornly continues trying with no result.
On an Android phone with K9 version 24.0 updated as of mid October.
Tried the Sync Account, but it didn’t seem to do anything.
Any ideas on what is happening?
First off, ensure connections can still be done. Maybe your OAUTH connection needs an update.
From any mailbox, hit the menu top left and choose Settings on the bottom. Choose your Yahoo account.
Choose Fetching mail. Choose Incoming Server second from bottom. Click Next. It will check fetching and either be clear, or prompt you to do something. When that works… go back to the previous menu.
Choose Sending mail. Choose Outgoing server as the last item. Tap next. It will connect and go back if the sending connectivity worked, or prompt you to reconnect if it didn’t work.
Try those two actions, and report how it goes.
Thank you! It had me login to yahoo and grant permission for K9 and is working again. Yay!!
Thanks also for the clarity in your instructions, they were very easy to follow!
Great. You may have to repeat this from time to time, as OAUTH connections have a lifetime set by the server side. The server might also auto log you out if you appear to connect from a strange foreign country. Depends.
But glad you are back.
