Pasting multiple email addresses
We still cannot paste multiple email addresses into the (To, Cc, Bcc) fields.
Is this a known issue on the roadmap to be fixed?
I hope it will be fixed soon… Too bad one can’t just paste a bunch of emails in the “To” section. Should be a quite obvious must feature… Sad
Two months and still no developer response on this.
Considering that a) Thunderbird for Android is on its way (in Beta as we speak) and b) that this is not a critical bug (in my personal opinion), I would not good my breath waiting for this to be fixed at all.
I anticipate that K-9 will be considered dead in a not very distant future. Hopefully Thunderbird for Android does not have this problem.
Can’t I just paste multiple email addresses from my address book like in the screenshot?
You can paste from the clipboard in the same way by separating the email addresses with a [,] comma.
Nope. Does not work.
Tap the three dots in the upper right corner of the compose mail screen to open the menu, then tap “Address” to add an email address from your address book.
Can’t you add it with this operation as well?
No.
Entering an email address is not / should not be contingent upon it existing in an “address book”.
