I can’t see my sent items on android.
Please can anybody help?
Have a look at Settings / < account > / Folders if the correct folder is set at Sent Folder.
Thanks for Reply,
I did that I check Settings / < account > / Folders and I set that when I am sending emails from my smartphone they have to be load in send folder,
but I don’t see my send folder (picture below)
And my sent emails from my smartphone are not seen in send folder on my lapotop either.
I don’t know what I have to do?
Bye Vinko
Tha language is Slovenian. ‘Prejeto’ means received & ‘Odpremni predal’ = send box
Do you use pop3 or imap to access the mailbox?
I have set
automatically detect the IMAP namespace
I guess that setting is only displayed when actually using an imap account. What did you select in Settings » Account » Folders » Displayed Folders? Try setting that to “all”.
Yes I have I set that already ;(
Hmm and “only show selected folders” is disabled?
