is it possible to switch from a Google play installation 5.6 to F-droid 5.7 without losing all settings? First I should uninstall the old Version?
Thanks for help,
Rut
I would use the following steps to switch to F-Droid:
- Export your settings in the Google Play version
- Uninstall
- Install from F-Droid
- Import the settings
Some remarks:
- Importing/Exporting the settings will work if you switch from an older version to a newer version (regardless of where you get it). Switching back to an older version can lead to problems.
- The settings export does not contain passwords. You will have to enter them again, so make sure you know them.
Thank you, Bytehamster!
