When I delete emails, they stay in the inbox. They are only gone when you delete them the second time. What can I do?
hello, yes, that’s how I set it. But it does not work. They are only removed after repeated deletion.
Then I don’t know, sorry - maybe someone else has an idea
Maybe related to mail provider?
@Stefan_Schatton: which provider do you use? If someone uses the same then she/he can test that specifically.
If that does not help then maybe some debug logs are necessary - but I do not know much on Android programming / debugging…
Hello!
Thanks…i am from Germany.
The provider is:
mail.muenster.de
But the problem ist also at the G-mail account.
Thanks…Stefan
