I reinstalled K-9 on My new tablet, buy it cannot see my contacts.
How can I make sure it will see them?
Do you mean the contacts that are stored in the contact application? This is independent from K-9. K-9 can query them but the actual management is done by the contacts app.
I found the solution.
In the settings the read e-mail and remove e-mail were switched off.
and I switched the contacts on and off.
Great to hear!
Just in case someone else runs into the same problem and finds this thread: you mean the contacts permission in Android’s settings app, right?
That is correct.
Put everything of and on again.
