I have 2 phones. Both had compose pencil but mot 1 had disappeared
Any idea how to get it back
Is there a compose button when you press the 3 dots in the upper right?
Yes…but the pencil is gone
Crazy thing is its on my S22 but my S22 Ultra is gone…
It was there yesterday
I have 2 phones. Both showed pencil to compose. Lost 1 somehow. How do i get it back
My guess would be that either the folder name or the account name is too long and it does not fit into the top bar.
I checked - I used a long folder name and also extended my account name. In both cases the compose button was displayed correctly, folder and account name where shortened by …
@Rich_Osborne In the 3dot menu the pencil is visible? Also, what happens if you turn the phone in landscape mode? Compose visible?
Edit: just saw that on another thread you posted already an answer to my 1st question:
Ok…ur on to it now…if i go to lanscape its back…how do i fix it
What version of K-9 you are using? Please exact version, not “latest”. Are you using same version on both phones.
Maybe my tests are not representive as I am using Beta 5.912.
I am not a K9 developer so I cannot help directly, just trying to get as much information which might help to understand why you see different behavior.
I agree with @ByteHamster that this somehow might be caused by your local settings/layout.
Maybe you can post a screenshot of the two devices? Make sure you make personal data unreadable.
What do u wanna see on my 2 phones exactly. Where do i go.
My other phone is on version 5.806
Correct. Thats where its missing on mine
Ok, one difference I can see that you do not have an account name displayed below “Inbox”. Is that the same on other device where it is working?
Yes.both phones are the same there
I found the issue guys. Much appreciated. I wouldnt have thought to look without your help.
Screen zoom was 1 spot larger on phone with issue.
Maybe you can mark this thread as solved?
Still I think devs maybe should have a look at it as even with higher screen zoom it seems to be pleanty of space for a 2nd button for compose.
How do i mark resolved
I see that other threads have just added “[Solved]” in front of the title - you should be able to edit it I guess.
@ByteHamster : on different Discourse based forums I have seen that threads can be marked as solved by marking a post as solution for it. Is this possible in this forum as well?
